Deletes prefixes from the router discovery advertisements on the VLAN.
| vlan_name | Specifies an IPv6 configured VLAN. |
| prefix | Specifies the prefix to delete. |
| all | Specifies to delete all prefixes. |
N/A.
This command deletes previously defined router advertisement prefixes.
The following example deletes the prefix 2001:db8:3161::/64 for the VLAN "top_floor":
configure vlan top_floor router-discovery delete 2001:db8:3161::/64
This command is available on the platforms listed for the IPv6 unicast routing feature in the Switch Engine v33.1.1 Licensing Guide document.
